I use the line in on the Up2stream Pro V3.
Everything worked fine and after about 2 hours only 1 channel was still working.
On the left channel, music can only be heard very very softly.
I have reset Mini and Pro. The output is set to stereo (L/R) on both up2streams.
I have tested the fixed connection (4pin) and also 3.5mm jack, the same error on both plugs.
What could be the fault?
Hi Linus2001,
Welcome to the forum.
So just to clarify, you have an audio source into the 3.5mm input jack and you are streaming to a mini, and both boards are showing the same LH channel problem?
Have you tried from another source and see if you have the same problem? Maybe try using the USB from a pc, AirPlay or Bluetooth and see if the Pro v3 displays the same issue.
Steve
Yes, i tried different sources and different cables on the jack input, same problem.
Left channel is missing on jack out on pro&mini
Wifi playback with app and Bluetooth works fine, stereo stream on pro and mini.
Hi Jan,
Probably can’t help you with this as it appears to be a faulty board.
I would suggest that you email customer support and inform them of the issue.
Steve
