Up2Stream Plate Amp 2.1 Source Indication LEDs
Hello, has anybody an idea why the 2.1 Plate amp has 4 GPIO Pins for source indication while it has 5 selectable inputs? I understood the following list: white > Wifi / blue> Bluetooth / green> Line / red> USB / ???>Optical .
So how can I indicate the selection of the optical input with a LED? Which GPIO input should I use to indicate that? Or is optical tied to “Line”?
Thank you for support!
