up2stream Amp v4 Qobus login doesn't work after factory reset
Firmware version 4.6.415145.36
Before Qobus was working. But I had to change the Wifi SSID, and this doesn’t work. So I did a factory reset from 4stream. Now I can select another wifi network, but Qobus login doesn’t work anymore.
I always get “login failed”…
Spotify is still working, but I want to use my Qobus subscription… Does someone have had simular problems, and possibly a solution to solve it?
Today i tried it with wired ethernet… the same result, no connection with Qobus…
My WIIM mini is still streaming from Qobus…
same problem with Qobuz in UP2stream (same firmware version 4.6.415145.36) and S10 (firmware version 4.6.415145.35): “login failed”…
It starts a couple of days ago.
I think factory reset it is not the source of the problem: to me happened during normal use.
My devices are connected via ethernet.
Same Qobuz account on Qobuz app works fine, so I think it is a problem in Arylic devices: Qobuz need now an updated authentication mode?
I hope the problem can be solve soon.
Regards.
Yep, same issue on S50 Pro plus. Stopped working, tried a factory reset, still get ‘login failed’ message
Same problem with S10+. I hope it’s not the same problem as with Deezer, which didn’t work for a year and then was removed from the application.
Hi, got some information from Arylic via email…
Hi Werner,
Qobuz is update some settings recently, please try again after few days,
Thanks
I seem to still be able to use Bubbleupnp to stream Qobuz to my S50Pro +. You could try that if stuck and 4stream won’t login
the same problem on s10 and a50. qobuz stopped working on these devices.
Hello, I have the same problem. I can’t enter qobuz with the 4stream app. I bought this device (s10) to use with my Qobuz subscription. Can anyone inform?
