I have still one Arylic S10, without the reset button on the outside (an early version).
It has been used on another WiFi network then mine, without first resetting it. So I have no way of accessing it with the 4Stream App to reset to factory settings.
Question
Is there any way to reset the S10 to factory settings, without opening the case and pressing the reset button on the PCB?
Maybe a secret key combination on the remote control?
Maybe via the Bluetooth connection? (I can connect via Bluetooth)
try connecting by ethernet cable and use an IP search tool to find devices on your network (Fing app for iphone). You then should be able to access the webpage and do a reset to factory settings from there.
This was a real good suggestion, to hook the S10 physically to my network.
I used Fing to find the device, which worked.
But when I (just by coincedence) opened my Device list in the 4Stream APP, it showed the S10.
So, now knowing this, there are two easy ways to factory reset the old S10 (without reset button):
Look it up wuth Fing and use the IP-address to access is via the web browser and reset it from there.
Open 4Stream App and the Device list, factory reset from there.
