Need good advice
Hello all.
I’m building, again. Just, you know, for me, that small mode led isn’t enough. So i thought I’ll hook up a led strip, sure over a relay. But… ehmmm. I ran out of ideas how i should do that. I thought I’ll just put a relay module that can be controlled by GND signal.
Nope. As the amp2.0 starts all relays are switched on. Not that plan. So I thought ok, I’ll put a led, with 1K resistor, like it should be and then take the one of led’s GND outputs.
Failed.
Any ideas ladies and gentlemen how I could contol led stripes with actual mode (white, green, blue, red)?
Your help would stop from getting my hair so fast grey.
Right. Some pics for my project
