Thanks for your response. I’m indeed looking for more physical buttons as apposed to software control.
I’ve found out that the adc key works in increments of 0.3V, up to 3V. That makes me think adding more buttons isn’t possible.
It would be great to be able to adjust the existing keys. The mode key for example has the same function as the reset key, so i won’t be using that. To be able to reconfigure that one to preset 5 would be great.
You can use physical buttons to use all 10 presets. When streaming, you just press “next song” button longer, and it go to next preset. Same works with for “previous song”. Hope this helps.
Thanks for the reply. Wasn’t aware of this function so learned something new, thanks!
In this case this “workaround” doesn’t work for me, but it is nice to know this is possible.
As I mentioned before, I think it would be great to be able to modify the function buttons functions. Maybe this could be done in ACP Workbench?
