help with remote control
Hi
I have a remote with the numbers at the bottom. For the life of me i cant figure out how to program them or even use them .
Can anyone share their experience?
When you listen to deezer/qobuz/Spotify etc music services, and beside the playlist, you should find a little speaker icon to add current playlist to preset. And it support 10 presets, the digital number on remote can call the first 6 presets directly. For example, you’ve preset a playlist on #1, then press number 1 will load that playlist and play.
Thanks
