Running fw. 4.6.337862.30 in a S50 pro+ there are random dropouts in the audio when playing TuneIn stations for a while. I use the S50 pro+ as a master and several V3 mini’s as slaves. The mini’s are running fw 4.6.337862.29.
It can be resolved temporarily by pausing the audio for a few seconds and then press play again, so it looks like it is a buffering issue. When resolved, the problem may disappear for days.
The dropouts are present in all connected devices in the group.
Anyone experiencing the same issues?
Been having the same issue on two v3 minis & two v3 pros for months. Happens with Spotify as it does with Tune In. Had many conversations with Support and they refused to fix it or provide any work around. Advertised to work with airplay and thought that might be my workaround until I found out it doesn’t work at all. False advertising.
